removing excess carbon?
Today i was doing my headgasket on my crx (still in the process) and when i pulled the head the top of the pistons on cylinder 1 and 4 are CAKED with carbon. My question is what is the best way to remove it without doing any damage to anything? I've searched here and couldn't find anything and google gave me a lot of results but for turbo dodges and other cars/trucks. I just want some fellow honda owners opinions on this. Any help is appreciated
One more thing, i'm installing my oil pressure gauge in the process of this and the fitting i have seems to be a little too big (1/8 npt i think). What fitting do i need, and if anyone would happen to know where to get it? thanks again guys.
Re: removing excess carbon?
most likely the reason ALL of your pistons are not coated with carbon is due to your headgasket blowing between cylinder 2 and cylinder 3.
just try to brush off with a stiff PLASTIC bristle brush the excess carbon. you can use gas or kerosene to clean it more without harming anything.
after it is back together... run a can of seafoam thru your fuel system
that should help.
the coolant flowing into your compression chamber caused the 2 and 3 pistons to basically clean themselves off.
that should help.
that should help.
that should help.
4 inch grinder with flapwheel. Okay Im joking, I've had good luck carefully using scotchbrite to just knock off the big stuff while using a shopvac to try to collect most of the debris from falling in the cooling ports. Don't go too crazy cleaning up, carbon isn't a bad thing unless it is so extreme your compression is raised to where you are detonating. Have yet to hear of that actually happen though.
stuff rags in each cylinder and use 600 grit or higher sand paper. remove rags after done and make sure material bits didnt get into the cylinder, that or brake clean works well once sprayed on rags and rubbed on the surface..
ill have To give that a try. I literally have been scrubbing at it with scotchbrite and gasket remover since 10am. I noticed quite a bit of gunk and gasket and other materials/chemicals have nearly flooded the cooling channels, how do i get all that out?
the cooling channels arent that big adeal as you can flush those out fairly easy. Try turkey basting the crap out of the coolant channels the best you can.. just run a hose through it later once you completed everything u needed to do. scotch brite pads work okay, but what you need is a 3m red cloth much more abrasive then those washing sponges lol
Thanks for the help so far guys. Here in a few minutes im gonna grab the turkey baster and the last bit of hope i have in me and scrub the **** out of the block lol. If that fails like it has been im just gonna rip the F23A1 out of my accord and stuff it in the little bastard
Why in the hell would you remove all the carbon when it will be back on the cylinders in 10 seconds of running.
Also, carbon crystals on the tops of pistons is a natural cooler and resists detonation. As well as minimally raising your compression ratio.
If you have thick moist carbon on a piston, of course remove that. But you don't have to spit polish them.
but hey.. in the end.. a tiny mini specs left are okay.. I have never had a problem with tiny spots that you could see.. main thing is to get the high spots off. If you can feel the spots with your finger nail thats not good, but if you cant feel them, dont beat yourself up over it.. :-)
turbotime
06-21-2006 06:56 PM
Nsane1
07-01-2005 08:01 PM
ASSASSIN
09-24-2004 04:50 PM
