probably talked about to death but....
I'm sure this topic's been up before, but I can't find it in any of my searches:
I'm planning to buy a "88-91 (B16A Sir 1) Complete Change Over" from http://www.hondamotorsonline.com and I have a couple of questions for people who have purchaced from them before.
1. They list that it comes with axles and half-shaft. Will these work on the USDM 91 civic std hb (with the si hubs and knuckles) or do i still need to get some 90-93 teg axles?
2. I think I know the answer to this, but just to be sure, they list that it comes with mounts. I still need aftermarket swap mounts, right?
3. same as #2 only for shift linkage.
4. They list engine harness. Is it enough of a harness to swap out my STD harness to MPFI?
and finally 5. I've seen elswhere on the board that the factory LSD tranny is not a good idea and that I'd be better off getting a non LSD and putting an aftermarket one on. any opinions?
Just Ignore this post if you're tired of these questions.
[Modified by thumpu77, 6:55 AM 2/5/2002]
[Modified by thumpu77, 6:56 AM 2/5/2002]
Re: probably talked about to death but.... (thumpu77)
when you do a search, make sure to click "post bodies" under the "search in" portion. the default place to search is topic titles and usually that doesnt return and info....
BigPlansNoMoney
03-02-2005 05:32 AM
p3s7
10-15-2003 10:45 AM
