Parasitic Draw involving + alternator term, underhood hazard fuse, radio and cigarett
Old 12-14-2011, 01:34 AM
I Deliver
EJAYATE's Avatar
Default Parasitic Draw involving + alternator term, underhood hazard fuse, radio and cigarett
I have a parasitic draw of 400ma that happens when the positive alternator terminal, hazard fuse under the hood, and radio/cigarette lighter fuse under the dash are plugged in. The same amount of draw happens when any one or all of those three are plugged in.
Does anybody know any components that involve all three of these circuits?
The radio is disconnected, ecu unplugged.
Car is a civic wagon rt4wd, obd1 conversion using rywire adapters (no chopped up harness)
Old 12-14-2011, 02:19 AM
I Deliver
EJAYATE's Avatar
Default Re: Parasitic Draw involving + alternator term, underhood hazard fuse, radio and ciga
Im thinking maybe its the ICU?
Old 12-21-2011, 01:02 PM
$cat /dev/urandom
sanimalp's Avatar
do you have a car alarm? my money would be on that. what about a ridiculous stereo system? those are also notorious for drawing too much amperage when the car is off.
otherwise, your ignition switch might be shorting out, causing a parasitic draw. The only things that should be drawing anything with the car off is the dash clock and radio, which incidentally are on the circuit you are talking about. 400ma is way high for those things though.
Old 12-21-2011, 07:24 PM
JOE BD-0's Avatar
Could be diodes in the alternator or possibly electronic door switch actuator if that car even has one? Good Luck...
lsb18_hatch
04-06-2009 03:02 PM
RacerBoy
Audio / Security / Video
06-23-2008 08:15 AM
Syndacate
32
07-12-2007 09:08 AM
UpstateCivic
04-15-2004 03:22 PM
Quick Reply: Parasitic Draw involving + alternator term, underhood hazard fuse, radio and cigarett
