O2 Sensor/running rich?
Old 06-15-2008, 09:29 AM
Dave9212's Avatar
Default O2 Sensor/running rich?
working on son's 88 civic DX 1.5 DPFI with a header on it
just replaced tandem control valve solenoid
and getting a code 1
I also put in new O2 sensor and still get code 1
check engine light comes on after a few miles down the highway
other than that it runs fine.
Any suggestions ?
Old 06-17-2008, 07:33 PM
Dave9212's Avatar
Default Re: O2 Sensor/running rich? (Dave9212)
Ok put a new O2 sensor in drove car about 10 miles a CEL popped on
Code 1 shows up still Could I possibly be reading codes wrong?
Wouldnt be no problem but son is supposed to be leaving in a week to go 300 miles away for summer so wife wont let car go until this is fixed.
Old 06-17-2008, 10:18 PM
soulpwr's Avatar
is it a long blink or a short one?
Old 06-18-2008, 07:57 PM
Dave9212's Avatar
Default Re: O2 Sensor/running rich? (soulpwr)
tried unplugging intake-air-temperature sensor to see if I was getting code 10 instead of code 1 that has 10 blinks.
I am only getting 1 blink when light comes on
I soldered wires together instead of the metal crimp still no luck
The light seems to come on after a few miles at highway speed
Thanks
Old 06-22-2008, 07:08 PM
Dave9212's Avatar
Ok Quick question
What size wire runs from O2 plug to terminal up by fuse box on passenger side wheel well? is it any type of special wire?
Old 06-22-2008, 08:07 PM
CR3X's Avatar
I wouldnt worry too much if its the o2 sensor. Whats gonna happen is when you start your car you run open loop. This means the PCM does not recieve information from your o2 sensor untill youve reached operating temp. When you do if something is off you should throw a MIL which you are. If it is the o2 sensor and the PCM is getting a bad reading it will revert to a preprogramed fuel trim so you dont run extremely rich or lean. This shouldnt cause the car to run rough. Check your code again and if that doesnt help go to hondatech.info click on auto on the left side of the page then manuals in the middle of the page and the desired vehicle. This is an official Honda service manual you can download for free. Its about 2000 pages but its got the information you need.
Old 06-23-2008, 07:58 AM
misha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulpwr &raquo;</TD></TR><TR><TD CLASS="quote">is it a long blink or a short one?</TD></TR></TABLE>
its obd-0 so its one short blink
Aslo that might not be related much but i had a a code one come on when my tming was a tooth off and i was getting to much air, so it woudl happen few miles down the high way.
Old 06-23-2008, 08:18 PM
Dave9212's Avatar
Default Re: O2 Sensor/running rich? (misha)
Thanks for all the input Found the problems .
Crack in header and wire for O2 sensor grounding out.
Just drove it 100 miles and no problems
My kid is happy again
Thanks
Old 01-13-2009, 11:40 PM
notAdiesel's Avatar
are there any manuals like these for an 00-01?
Old 01-14-2009, 06:28 AM
Coltmorris's Avatar
nvm
Elson23
11-21-2009 08:40 AM
slim689
04-19-2007 10:55 AM
Koyoloeor
10-13-2005 04:57 PM
Carp
10-10-2002 08:14 AM
RJL
11-25-2001 04:36 PM
Quick Reply: O2 Sensor/running rich?
