check engine light
Old Apr 18, 2007 | 05:08 PM
slim689's Avatar
Default check engine light
ok so i replaced my oxygen sensor today and im still throwing a code, will i have to get it reset or will it clear by itself after a certain number of miles....
Old Apr 18, 2007 | 08:57 PM
JimBlake's Avatar
Default Re: check engine light (slim689)
What code was it throwing?
If it WAS the O2 sensor, it should clear after a while. How long? It's not just miles, it's drive cycles & more. If the new O2 sensor doesn't fix it, it'll keep throwing the code.
Old Apr 19, 2007 | 03:55 AM
slim689's Avatar
Default Re: check engine light (JimBlake)
i know it was the o2 sensor code for sure
ok but heres the thing....i hand tightend the new o2 sensor into the cat because i didnt have a wrench....it was in there pretty snug, but if by some chance its not tightend enough would the code just stay on and not go away
Old Apr 19, 2007 | 04:31 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim689 &raquo;</TD></TR><TR><TD CLASS="quote">i know it was the o2 sensor code for sure</TD></TR></TABLE>Well, there's 8 different codes for the O2 sensors. I was wondering which one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim689 &raquo;</TD></TR><TR><TD CLASS="quote">ok but heres the thing....i hand tightend the new o2 sensor into the cat because i didnt have a wrench....it was in there pretty snug, but if by some chance its not tightend enough would the code just stay on and not go away</TD></TR></TABLE>
The O2 sensor actually measure oxygen DIFFERENCE from inside vs. outside of the exhaust pipe. Exhaust leaking out over the outside of the sensor will throw off that measurement. It takes awhile before the CEL turns off, but I think the code remains stored. It's not a set number of miles or a set number of start/stop cycles. Its a combination of lots of things that have to be satisfied before the readyness codes are all set.
Tighten the sensor properly.
Have someone read the code & tell us the number.
Reset your ECU.
Let us know if the CEL comes back.
Old Apr 19, 2007 | 10:55 AM
russianswty's Avatar
Ok dont guess that you have a oxygen censor code. Actually find out what it is.
Second of all go and get a oxygen censor socket and tighten it up.
You can rent the tool from autozone for 15 bucks and you get a full refund when your
done.
If your car is a 96+ then you can go to autozone, schucks or anybody who does free
testing and asking them to scan your codes. If its older you can find in a manual
how to check it your self.
Spug
May 26, 2012 12:15 AM
bma1818
12
Feb 3, 2007 10:45 AM
Mr.Speed
Feb 21, 2006 08:15 PM
s14hybrid
Nov 24, 2004 05:16 AM
Lewie
Jun 30, 2004 11:33 AM
