need help running grounds
Old 08-06-2017, 05:56 PM
1320london's Avatar
Default need help running grounds
i have a obd0 crx the im trying to get the starter to engae on and all it does is make the main relay click, i know its not the starter. I have one ground where the bracket is on top of tranny to the chassis,one from the block to chassis, the ecu wires to the thermostat, and i added another one just to see what happens from the starter to the chassis. any ideas of how to do it to where theres no way that would be the problem.
Old 08-06-2017, 07:53 PM
Keyboard Humorist
4drEF's Avatar
Default Re: need help running grounds
Try connecting one cable from a set of jumper cables from Neg battery and the other end clamp to an ear on the distributor. That's as good of a ground that you can get to test for the starter to work.
Old 08-08-2017, 05:24 PM
1320london's Avatar
ok i tried that didnt help i also bypassed the clutch safety switch, checked the volts there at 11.91 the main relay has one loud click and the relay behind the radio clicks as well
Old 08-08-2017, 06:44 PM
EFB055
~sp33~'s Avatar
Are you trying to find out if the starter works? Or if there's a fault with the electrical system?
Old 08-09-2017, 11:51 AM
1320london's Avatar
i know the starter works just cant get it to turn over or do anything everybody says its a ground but its grounded very well.idk what all goes into making the starter work from the eletrical part
and just to be certain do the grounds have to go excatly where they say to or would it still ground if its close, i have one running from the top of hte head to chassis,clutch cable bracket to chassis,the ecu to thermostat, starter to chassis,
Old 08-09-2017, 01:59 PM
1320london's Avatar
ok found the first problem the starter gear isnt kicking out but it still will not do anything from the key, i had to engage the solenoid manually. i found the starter relay and it is making a sound as well, does it mean its bad .
Old 08-10-2017, 02:13 AM
RTFM
v4lu3s's Avatar
Replace it.
Old 08-10-2017, 07:23 AM
Keyboard Humorist
4drEF's Avatar
are you 100% sure your battery is fully charged?
Old 08-10-2017, 11:35 AM
1320london's Avatar
no doubt i pull i out of my f250 everytime and put it baick in the truck when im done its been sitting a year while the motor got rebuilt but it didnt do this before
Old 08-11-2017, 01:54 PM
1320london's Avatar
ok im geting 12v to the big starer wire and 12v to the blk and wht
Old 08-13-2017, 01:48 PM
EFB055
~sp33~'s Avatar
Bench test the starter first.
The circuit is pretty simple, Battery to fuse box, fuse box to starter. The black/white wire comes from your ignition switch.
Download the 'CRX Workshop manual' (which is valid for all ED/EF), it's got circuit diagrams, troubleshooting flowcharts, everything you need.
Old 08-13-2017, 05:11 PM
tamboo's Avatar
sent you a pm with link to manual, cant post it here. 8(
JuneBugDrfter
01-08-2014 11:03 PM
jdmmugeneg6
11-22-2013 06:21 AM
honda head
01-28-2007 01:35 AM
rolledthatho
08-24-2005 08:26 PM
decible01
10-03-2004 03:45 PM
Quick Reply: need help running grounds
