Which Limited slip set up should I use
Trying to decide which route to take need the traction Phantom Grip, OBX LSD, ???? anybody want to share the setup please
Pirate General...YARRRR
Re: Which Limited slip set up should I use (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">Quaife </TD></TR></TABLE>
Re: Which Limited slip set up should I use (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Re: Which Limited slip set up should I use (hughesl)
checked the website also checked authorized dealers no one sells any for a 88-91 si trans
Re: Which Limited slip set up should I use (llslick)
Now with a little research, you will find out which later ones are compatible with the different 88-91 boxes.
Crazy Honda Guy
All the way, much better quality and performance than those cheap ones mentioned in the 1st post
Re: Which Limited slip set up should I use (dr_latino999)
Mfactory has a new gear type LSD for 650.00 and they make good ****.
OBX = CRAP
phantom grip is 300.00 for way less performance.
OBX = CRAP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llslick »</TD></TR><TR><TD CLASS="quote">checked the website also checked authorized dealers no one sells any for a 88-91 si trans</TD></TR></TABLE>
I checked the website for quaife and they list a part number for a 88-91 si or non si
60.309.150 $950.00
60.309.150 $950.00
Re: (greyrex)
Not sure about the Y1 but I am running the B16 one in my S1 trans.
I am very happy with it. About 3 weeks ago I was able to set FTD for cars at my local autocross.
I believe the Quaife was a big part of that.
Thanks for the input.
I'm actually using a cusco full lock on my y1 g/box and plan to get a set of quaife lsd for my additional g/box if it could fit.Had pm one of the seller of quaife and waiting for his reply.Will keep you guys update.Cheers!
Re: (greyrex)
Thank you everyone for all the input. If you want the performance you gotta pay the price $950 for a LSD looks like I have some saving to do
1 Post
Re: (greyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greyrex »</TD></TR><TR><TD CLASS="quote">Thanks for the input.
I'm actually using a cusco full lock on my y1 g/box and plan to get a set of quaife lsd for my additional g/box if it could fit.Had pm one of the seller of quaife and waiting for his reply.Will keep you guys update.Cheers!</TD></TR></TABLE>
where did you purchase the cusco one from??
I brought this lsd with the Y1 g/box from a guy in Penang,Malaysia.
Btw,i dun think cusco comes with a lifetime gurantee unlike quaife - pls correct me if i'm wrong.
Re: (greyrex)
I don't know if all the people telling you that the OBX unit is junk even have any experience with one. However, I have had mine in my car for almost 2 yrs now, and have had absolutely ZERO problems with it. I've tracked the car(road course & drag) Not to mention I live in the Mtns. aswell, so my car sees ALOT of abuse daily, and my EF puts out 200+hp also. If you get one, buy the upgraded bolts & washers set. Strip it down replace those, and re-torque everything and you figgin set for 1/3 the cost of the quaife. If your ballen though, go ahead and get the quaife so the fan boys will like you.
I personally don't have a chance to try out the obx lsd as nobody brings it to Singapore/Malaysia and japs stuffs would be the easier choice.I have read about the durability of quaife lsd and i reckon that it might be good.
Re: (greyrex)
Thanks alot slowhatch i think alot of us needed to hear that I'm building a lowbudget wonder and $950 for a lsd is just not gonna happen once again thanks
