Which Limited slip set up should I use
Trying to decide which route to take need the traction Phantom Grip, OBX LSD, ???? anybody want to share the setup please
Re: Which Limited slip set up should I use (llslick)
Going into a stock ef si trans
Quaife
FV-QR
Are there any LSD's for the 4wd civic wagon?
Re: FV-QR (~sp33~)
thanks for the info anyone else
Re: Which Limited slip set up should I use (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">Quaife </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Which Limited slip set up should I use (Ass$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ass$nyper »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Which Limited slip set up should I use (hughesl)
checked the website also checked authorized dealers no one sells any for a 88-91 si trans
Now with a little research, you will find out which later ones are compatible with the different 88-91 boxes.
All the way, much better quality and performance than those cheap ones mentioned in the 1st post |
Re: Which Limited slip set up should I use (dr_latino999)
Mfactory has a new gear type LSD for 650.00 and they make good shit.
OBX = CRAP phantom grip is 300.00 for way less performance. |
Re: Which Limited slip set up should I use (Ubertec)
Quaife https://honda-tech.com/forums/images/smilies/emthup.gif
They have a lifetime warantee even under racing conditions. |
Will the quaife lsd works with a b16a1 g/box(y1)?Thks.
i agree quaife
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llslick »</TD></TR><TR><TD CLASS="quote">checked the website also checked authorized dealers no one sells any for a 88-91 si trans</TD></TR></TABLE>
I checked the website for quaife and they list a part number for a 88-91 si or non si 60.309.150 $950.00 |
Re: (greyrex)
Not sure about the Y1 but I am running the B16 one in my S1 trans.
I am very happy with it. About 3 weeks ago I was able to set FTD for cars at my local autocross. I believe the Quaife was a big part of that. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (greyrex)
I believe cusco makes one as well
Thanks for the input.
I'm actually using a cusco full lock on my y1 g/box and plan to get a set of quaife lsd for my additional g/box if it could fit.Had pm one of the seller of quaife and waiting for his reply.Will keep you guys update.Cheers! |
Re: (greyrex)
Thank you everyone for all the input. If you want the performance you gotta pay the price $950 for a LSD looks like I have some saving to do
Re: (greyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greyrex »</TD></TR><TR><TD CLASS="quote">Thanks for the input.
I'm actually using a cusco full lock on my y1 g/box and plan to get a set of quaife lsd for my additional g/box if it could fit.Had pm one of the seller of quaife and waiting for his reply.Will keep you guys update.Cheers!</TD></TR></TABLE> where did you purchase the cusco one from?? |
I brought this lsd with the Y1 g/box from a guy in Penang,Malaysia.
Btw,i dun think cusco comes with a lifetime gurantee unlike quaife - pls correct me if i'm wrong. |
Re: (greyrex)
I don't know if all the people telling you that the OBX unit is junk even have any experience with one. However, I have had mine in my car for almost 2 yrs now, and have had absolutely ZERO problems with it. I've tracked the car(road course & drag) Not to mention I live in the Mtns. aswell, so my car sees ALOT of abuse daily, and my EF puts out 200+hp also. If you get one, buy the upgraded bolts & washers set. Strip it down replace those, and re-torque everything and you figgin set for 1/3 the cost of the quaife. If your ballen though, go ahead and get the quaife so the fan boys will like you. http://is.rely.net/1-92-56342-l-HDIv...QjldAGcqmQ.gif
I personally don't have a chance to try out the obx lsd as nobody brings it to Singapore/Malaysia and japs stuffs would be the easier choice.I have read about the durability of quaife lsd and i reckon that it might be good.
Re: (greyrex)
Thanks alot slowhatch i think alot of us needed to hear that I'm building a lowbudget wonder and $950 for a lsd is just not gonna happen once again thanks https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (llslick)
