idle problem need help (searched)
Old 09-06-2007, 05:10 PM
crxfreak1117's Avatar
Default idle problem need help (searched)
ok i have a 89 crx b16 turbo and im having a idle problem it doesnt have a vacumm leak becuase im reading around 20-21 on the boost gauge at idle and when i unplugg the iacv the idle drops to about 400rpms and the idle goes from 1200-1550 up and down when hooked up and i cant find anything wrong?? it also has a bbk throttle body????????
Old 09-06-2007, 07:49 PM
maxx5905's Avatar
Default Re: idle problem need help (crxfreak1117)
IACV, Clean it out with some carb cleaner and put it back on reset ecu and if its still doing it need a new iacv.
Old 09-06-2007, 08:04 PM
ef-hatchcrap's Avatar
Default Re: idle problem need help (maxx5905)
Or you can just run a wire from the ecu to the iacv to see if that fixes the problem.
Old 09-06-2007, 08:15 PM
clarkey-ef-irl's Avatar
Default Re: idle problem need help (ef-hatchcrap)
could be your airflow meter?? i know this happened to a friend of mine last week..
Old 09-07-2007, 05:25 PM
Default Re: idle problem need help (clarkey-ef-irl)
ok cleaned it and still didnt work but woud that be the problem if i unplug it and it runs at like 500 rpms? also i might not said this before but it usually happens with it gets warmed up
Old 09-07-2007, 06:54 PM
abram_quito's Avatar
REPLACE IACV
OR CHECK VACUUM LEAK
Old 09-08-2007, 07:05 PM
maxx5905's Avatar
Replace the IACV or Check Vac. leak
crxguy406
09-10-2015 03:56 AM
immalooser
02-18-2009 05:23 AM
mikeunreal2
03-29-2006 09:27 PM
diLUDEd
08-22-2002 10:08 PM
Quick Reply: idle problem need help (searched)
