How do i get the timig cover off!!??
Im tryin to get the plastic timing cover off from behind the gears ib ny b18a1 how the hell do i do this ? Ive taken out every bolt ..its hittin my gears for some reason and need to get it off ..please help me out
Re: How do i get the timig cover off!!?? (Devin17)
Re: How do i get the timig cover off!!?? (MugenEF7)
Hm....ive taken all the top bolts off and almost all the rear ones...its the plastic peice behind the cam gears ....Still not movin for me
edit: So SoLLy
[Modified by MugenEF7, 2:05 AM 8/10/2002]
Yea i know looks like i might be screwed ..Im not gonna take the cam gears off ...Ah well ...Maybe ti will be ok ..the gears are eatin into the plastic though :\
Damn devin, you just dont have any luck at all do you? Well good luck to you
BTW, are you gonna sell that hb dash if you havent already? j/w.
I took way too long
yeah just lift off the valve cover then undo the two screws on the cover and take it off. i broke the back hole where the bolt goes and i had to glue it back together. no biggie. i also cut off that lip so now you dont have to remove the valve cover to get it on off. just things to keep in mind.
Ebony and Ivory
06-07-2005 09:09 AM
