Help with wiring mpfi
im using 0bd2 injectors and plugs due to i cant find a resistor box. i just dont know how to wire them up without using a resistor box
Re: Help with wiring mpfi (nitewolf)
i dont know if u can do that. because the original wire from the ecu goes to the resistor box. worse comes to worse just make a resisstor box from radio shack parts
Re: Help with wiring mpfi (97grnrs)
you can't use a resistor box with obd2 injectors - they are saturated. obd0 injectors are just peak&hold, they DO need a resistor box!
Re: Help with wiring mpfi (trackfan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trackfan »</TD></TR><TR><TD CLASS="quote">you can't use a resistor box with obd2 injectors - they are saturated. obd0 injectors are just peak&hold, they DO need a resistor box! </TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">i dont know if u can do that. because the original wire from the ecu goes to the resistor box.</TD></TR></TABLE>
<FONT SIZE="3">Adding OBD-2 Injectors</FONT>
OBD-0 MPFI W/ Injector Resistor Box
HOW-TO Delete The Box
MysteryWagon
06-17-2005 04:16 AM
