Starting Problems! HELP!!!
I seriously need to figure this out as the shop has gone thru their ideas and nothing worked. I have a H22 Civic Hatch and basically I try to start the car, it cranks sometimes, sometimes I just hear clicking. I think it could be the starter but when I hook up the car to a booster, the car starts up. I keep it running then I shut it down, I try to start it again without the booster... car starts... Now for possible solutions:
1. Main Fuel Relay has broken leads but by putting the booster, it's jumping over the broken leads. Will know if this is the problem tomorrow morning.
2. Starter, doesn't seem like it since I turn it off and try to start it again and it works.
Also unrelated but when I had my clutch replaced, oddly enough I can start the car without putting the clutch down. Clutch Safety Switch is plugged in but doesn't work...
Please help!!!
Please help!!!
Re: Starting Problems! HELP!!! (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Sounds to me like your battery isnt holding a charge very well. Have you ever mangaed to kill the battery?? </TD></TR></TABLE>
agreed
agreed
Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu »</TD></TR><TR><TD CLASS="quote">Battery is fully charged... Any more suggestions?</TD></TR></TABLE>
Try another battery. That or try taking it to Autozone and they'll check your ignition system for free.
Re: (Ricey McRicerton)
Try another battery. That or try taking it to Autozone and they'll check your ignition system for free. </TD></TR></TABLE>
Brand new battery. I actually did that prior.
Re: (Pikachu)
Brand new battery. I actually did that prior.</TD></TR></TABLE>
I'm stumped then. Definately sounds ignition related, so the main relay would'nt be it IMHO.
Re: Starting Problems! HELP!!! (Pikachu)
it can't be the starter, it makes a cranking noise. Maybe u have a drain somewhere in ur system, Check that. otherwise start it for a while and remove the ground and reconnect the next morning or in a couple of hour.
Re: Starting Problems! HELP!!! (EvilPhu)
check connections to the battery. make sure you have the right fuses... sounds like a power issue not a mechanical issue...
Found what it was.... It was the battery. It had enough voltage but when tested under the load test, it failed. It went all the way down to the bottom. Changed it, starts up perfectly now.
daniel990836
05-28-2009 09:57 PM
