timing help?
Old Feb 9, 2008 | 02:04 PM
98GSR-Turbo's Avatar
Default timing help?
i have had to replace the timing belt. and the belt seems no to tighten. i did what my book says to do. spin the motor counterclockwise about 6 times then go 3 teeth past TDC and loosen the tensioner bolt 180 degrees and tighten. well between the intake cam and the water pump pulleys its not tight i can still pull the belt off the intake cam pulley. then if i turn the motor over 3 more times between the exhaust cam pulley and the crank sprocket will be loose and the other side will be tight. is this supposed to be like this or what. if so any reason?
Old Feb 10, 2008 | 01:39 AM
David27's Avatar
Default Re: timing help? (98GSR-Turbo)
i have had the same problem take the belt off then losen the tensioner, push the tensioner up as far as u want it hold it while tighten it then but the belt back on, and if its still loose take the belt off push it up alittle more then tighten it down and that should work
Old Feb 11, 2008 | 02:14 PM
is the belt between the exhaust and the crank sprocket supposed to be alittle loose?
91 b20 integra
Sep 22, 2014 08:44 AM
bigizsosexy
May 21, 2008 03:13 PM
B18C5_VTEC
Nov 2, 2007 09:18 AM
AdamITR
Aug 28, 2002 07:11 PM
Mikey3000
Feb 7, 2002 01:44 PM
