bypass igniton key to close sunroof?
Old Dec 20, 2005 | 06:36 AM
.Noah Fecks's Avatar
Default bypass igniton key to close sunroof?
ok so ive had my car stored in a garage for a few months, and now i have misplaced the key. is there a way at all that i can by pass having to turn on the key to close the sunroof. i now have the car stored outside with a tarp over it. this is the love of my life and i would hate to see it get full of water.
thanks in advance guys.
Old Dec 20, 2005 | 06:48 AM
schwanginpt's Avatar
I'm pretty sure you can take your VIN to the honda dealer and get a new key cut for it. Should only be like $5-$10 tops
Old Dec 20, 2005 | 07:23 AM
CRX Toad's Avatar
Default Re: bypass igniton key to close sunroof? (Noah *****)
All you need to do it run hot line to the sunroof switch and it will close for you. Or you can disassemble your ignition and turn it on with a screwdriver.
Old Dec 20, 2005 | 07:39 AM
george34's Avatar
Default Re: bypass igniton key to close sunroof? (CRX Toad)
Can't u just lus a wrench? I have never used a wrench and don't know if the car has to be turned on for the wrench to be able to close the sunroof.
Old Dec 20, 2005 | 08:48 AM
bryant's Avatar
If you have the owners manual it says how to close it manually. There is a plug in the roof, pop that out. There should be a skrew or a nut, cant remember, and you just turn that and close it by hand.
Old Dec 20, 2005 | 08:49 AM
it's a nut, i think its a 17mm.
Old Dec 20, 2005 | 11:32 AM
manson's Avatar
Default Re: (schwanginpt)
there is a manual way to do it as said above.
im sure its not a 17mm its a small nut...something that can fit on the end of a screwdriver type attachment.
Old Dec 20, 2005 | 11:43 AM
H22a T13's Avatar
Yeah all you need is a ID, Your insurance info, and $$$.
Saved my *** for sure.
Old Dec 20, 2005 | 01:46 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (manson)
Back toward the dome light,there is a plug with a slot in it.
Turn to slot parallel to the car and remove the plug.
Under the plug,there is a place for a 5mm allen socket
and there should be a tool included within
the kit for changing the tire...
Old Dec 21, 2005 | 06:49 AM
Default Re: (88DXCRX)
thanks guys!
serr38
May 10, 2009 03:39 PM
dx_blk_hatch
Jun 11, 2008 03:36 PM
137
Sep 30, 2004 03:48 AM
Briman2021
Feb 3, 2004 12:03 PM
