B16a EE9 crank no start
Hi guys I rebuild my engine on my Civic ee9 b16a obd0 i ran car for 200 miles nice and steady I took it up to 6 thousand revs and then it starts to backfire like anti-lag, I then spoke to a garage as one day it wouldnt start and there was no spark from the dizzy cap, i was advised to replace ignition coil cap rotor arm and ignition control module, after replacing car turned on right away drove fine for a few days one day I was driving the car gave it a bit of stick up to 5.5K as has that Rev issue, i parked outside my house car was idling after a few minutes the cars bog down and shut off, i tried to start it kept cranking every so often it would turn on for a couple of seconds but when it turns on it would rev at 2k then it drops if i accelerate it'll cut out and if i leave it then itll cut out after 2 to 5 seconds, I left it a few days clean the spark plugs checked to the timing belt advanced the distributor a little bit then it turned on straight away and was idling fine I didn't drive it went back to the car a few days later still the same thing wouldn't start and if it does for a couple of seconds idles at 2K then cuts out any ideas guys i get the feeling dizzy is dying or something
adhd316
Honda CR-V & Element
02-06-2014 03:21 AM
djfob
10-23-2009 01:59 AM
