Ignition?
Old Mar 21, 2010 | 11:15 PM
clewis3's Avatar
Default Ignition?
I was driving down the highway when my started making loud thumping noises then died. I tried to start it and it barely turned over then thumped and died, forcing me to have it towed. Upon investigation, I noticed that the timing belt was worn, and had a tear in it but didn't break, but the engine had skipped time. I replace the timing belt and got it back in time then tried to start it. Still no start. I tested to see if I had spark, but it wasn't getting any. My car will crank but not start. I know it's not the starter, because my car cranks, but I'm thinking either the ignition coil or ignition module inside the dizzy. I've pulled the cap off, and can't get the rotor off, the screw won't budge, so I have 2 questions for the more knowledgeable gear heads out there, first, am I right in guessing my ignition coil and/or ignition module? And since I cant unscrew the rotor screw without completely stripping it, if I just break the rotor off, will it effect anything else or break my dizzy completely?
Old Mar 22, 2010 | 01:01 AM
simboy2003's Avatar
Default Re: Ignition?
it'll break it completely. is your cel staying on?
Old Mar 22, 2010 | 06:12 AM
213374U's Avatar
0x5359-0055
Community Builder
Use the penetrating lube of your choice on the rotor screw (soak for 5 minutes) and grab the head with a small pair of vice grips. Tap the vice grips with a hammer to break it loose and you should have it out no problem.
Old Mar 22, 2010 | 08:27 AM
clewis3's Avatar
No the CEL isn't on. No engine lights or maintenance lights of any kind are on.
Old Mar 22, 2010 | 05:08 PM
clewis3's Avatar
And I put a new dizzy on but still no spark!
Old Mar 23, 2010 | 12:05 AM
Lord Helmet's Avatar
check your firing order
Old Mar 23, 2010 | 12:28 AM
simboy2003's Avatar
^ still should have something. check your main relay. then your acg fuse. gl
Old Mar 23, 2010 | 09:08 AM
clewis3's Avatar
I did the "3 clicks test" to check the main relay haha, it checked out, but where is my ACG fuse? Just in the fuse box? and is there a better check the main relay?
Old Mar 23, 2010 | 11:49 PM
simboy2003's Avatar
ACG is under the dash fuse box, and find a friends car and swap out the mains to see if yours works just fine. easiest way to see if it works fine.
LMdb2teggy
May 24, 2010 12:29 PM
slikz714
Apr 27, 2009 03:18 AM
shadohconspiracy
Apr 15, 2008 07:47 PM
patrick4588
May 2, 2006 11:41 AM
jaybees
15
Apr 6, 2005 04:30 PM
