1989 civic si cel code 6 all stock
Re: 1989 civic si cel code 6 all stock
Yes, I seen that the coolant sensor wire was very brittle so I got another connector from the junk yard and a new coolant temp sensor from work and installed both today after installing both I pulled both negative and positive battery cables and held them together for a few minutes to reset the ecm after hooking everything back together and firing it up the cel light instantly came one again I noticed also this morning it took a few cranks for it to turn over , more than normal and the idle was a bit rough but seem to run good after a few minutes after fire up...and my problem didn’t start till yesterday evening
the coolant temp sensor that gives you a code 6 is a 2-wire sensor on the end of the head, below the distributor, with RED with WHITE stripe and GREEN with WHITE stripe wires -
sounds like you may have been confusing the temp gauge sending unit, which has a 1-wire connector (YELLOW with GREEN stripe), with the TW sensor for the ECU
Just adding to this^ information -- The Red/Wht wire should read ~5V and the Grn/Wht wire should read continuity to body ground using a multimeter.
Update:
thanks for all the help guys I really appreciate the quick feedback from everyone I ended up tracking the wires back up the harness and found a break in the wire and butt-connected it before work this morning and she fired right up with no cel light 👍🏻
A temp fixk until t can do it correctly this weekend but for now she is back on the road
Update:
found the problem, this morning I decided to follow the ect wire up the harness a bit and found out it was a broken wire...striped it and made a connection and connected the wire back to ect sensor and and the cel light went away and it started with no issues
thanks for all the help fellas I do appreciate it
nicefighter80
01-15-2011 08:53 AM
