1.5L distributor VS 1.6L distributor
Old 09-26-2006, 11:52 PM
alex17's Avatar
Default 1.5L distributor VS 1.6L distributor
Well I have come across a problem. I have 5 D15 heads sitting around and a D16A6 with a knock (head still attached and in great shape). The D16 does not have a distributor.
Distributors I have are.
90 CRX HF distributor (d15b6)
93 Civic EX distributor (d16z6)
I also have OBD0 wiring that will work with the 93 EX distributor. And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor. I noticed diffrent part numbers between 1.5L and 1.6L, will the 1.5L work with the 1.6L head? Also I am about to remove the cylinder head like I said because of a broken timing belt, Is there any links for a how to step by step? Its been a while, i remember a few things just want to cross my t's.
Old 09-27-2006, 12:02 AM
alex17's Avatar
Default Re: 1.5L distributor VS 1.6L distributor (alex17)
work in progress ^^^
Old 09-27-2006, 05:29 AM
Boosted Chemist's Avatar
use the hf dizzy if your staying obd0 and the ex if your going obd1, they are NOT interchangable. obd0 has 16 click for a full turn and the obd1 had 22 clicks for a full rotation i belive.
hondaswap.com has helms manuals for download for pulling the head
Old 09-27-2006, 05:43 AM
bag
bag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex17 &raquo;</TD></TR><TR><TD CLASS="quote">
And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor.</TD></TR></TABLE>
no it doesnt,,you gotta convert to mpfi to use the hf dizzy.
Old 09-27-2006, 06:37 AM
dr_latino999's Avatar
Default Re: 1.5L distributor VS 1.6L distributor (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">no it doesnt,,you gotta convert to mpfi to use the hf dizzy.</TD></TR></TABLE> Hey, now you never know if it has been converted
Old 09-27-2006, 09:45 AM
alex17's Avatar
Default Re: 1.5L distributor VS 1.6L distributor (dr_latino999)
whats the advantage of using the HF distributor if I am going to run mpfi? I pulled off the wire loom cover and its been spliced with another harness, thats why it plugs into dx harness. I also forgot to mention I have a stock 1.5L dx distributor. Will it work with the D16A6 head? Thanks for the link
any specific place to look for the manual? lol
Modified by alex17 at 11:28 AM 9/27/2006
Old 09-27-2006, 10:21 PM
alex17's Avatar
Old 09-28-2006, 09:21 AM
alex17's Avatar
Default Re: (alex17)
i guess theres nobody on here that knows where to find a writeup on tbelts
Old 09-28-2006, 09:38 AM
Default Re: 1.5L distributor VS 1.6L distributor (Boosted Chemist)
hondaswap.com has helms manuals for download for pulling the head</TD></TR></TABLE>
Huntley2147
01-29-2012 06:14 AM
kevcha711
01-21-2010 09:50 PM
dr_latino999
08-18-2005 06:21 AM
Quick Reply: 1.5L distributor VS 1.6L distributor
