1.5L distributor VS 1.6L distributor
Well I have come across a problem. I have 5 D15 heads sitting around and a D16A6 with a knock (head still attached and in great shape). The D16 does not have a distributor.
Distributors I have are. 90 CRX HF distributor (d15b6) 93 Civic EX distributor (d16z6) I also have OBD0 wiring that will work with the 93 EX distributor. And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor. I noticed diffrent part numbers between 1.5L and 1.6L, will the 1.5L work with the 1.6L head? Also I am about to remove the cylinder head like I said because of a broken timing belt, Is there any links for a how to step by step? Its been a while, i remember a few things just want to cross my t's. |
Re: 1.5L distributor VS 1.6L distributor (alex17)
use the hf dizzy if your staying obd0 and the ex if your going obd1, they are NOT interchangable. obd0 has 16 click for a full turn and the obd1 had 22 clicks for a full rotation i belive.
hondaswap.com has helms manuals for download for pulling the head |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex17 »</TD></TR><TR><TD CLASS="quote">
And ofcorse my STD wiring on my 1990 EF STD plugs and plays on the HF distributor.</TD></TR></TABLE> no it doesnt,,you gotta convert to mpfi to use the hf dizzy. |
Re: 1.5L distributor VS 1.6L distributor (bag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag »</TD></TR><TR><TD CLASS="quote">no it doesnt,,you gotta convert to mpfi to use the hf dizzy.</TD></TR></TABLE> Hey, now you never know if it has been converted https://honda-tech.com/forums/images...s/emsmilep.gif
Re: 1.5L distributor VS 1.6L distributor (dr_latino999)
whats the advantage of using the HF distributor if I am going to run mpfi? I pulled off the wire loom cover and its been spliced with another harness, thats why it plugs into dx harness. I also forgot to mention I have a stock 1.5L dx distributor. Will it work with the D16A6 head? Thanks for the link https://honda-tech.com/forums/images/smilies/emthup.gif
any specific place to look for the manual? lol Modified by alex17 at 11:28 AM 9/27/2006 |
Re: (alex17)
i guess theres nobody on here that knows where to find a writeup on tbelts
Re: 1.5L distributor VS 1.6L distributor (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
hondaswap.com has helms manuals for download for pulling the head</TD></TR></TABLE> |
