Honda CR-V & Element 2WD & 4WD Element & CR-V
02 sensor code p0141 seconary sensory light wont go out
Old 01-09-2011, 12:23 PM
maat4449's Avatar
Default 02 sensor code p0141 seconary sensory light wont go out
i got a code p0141, i replace the 02 sensor front and back and the code is still there? do you think it has to do with a faulty ,ELD,?
Old 01-09-2011, 12:32 PM
be professional
Targa250R's Avatar
Default Re: 02 sensor code p0141 seconary sensory light wont go out
Did you reset the computer after replacing the sensor?
Old 01-09-2011, 01:28 PM
maat4449's Avatar
YES
Old 01-09-2011, 01:39 PM
be professional
Targa250R's Avatar
Where did you get the sensor? What is the brand and part number? What year, model, and trim level is the vehicle?
Old 01-09-2011, 05:34 PM
maat4449's Avatar
part is a , OEXTRA, ROA1196, DOWN STRAM 02 SENSOR, I GOT IT OFF EBAY FOR $46, ITS A OEM PART, THE CAR IS A O3 CRV, LX 2.4 ENGINE
Old 01-09-2011, 05:58 PM
be professional
Targa250R's Avatar
"OEXTRA" is not an "OEM part." I'd never even heard of that brand prior to this.
The OE secondary heated oxygen sensor is likely either an NTK 24410 or a Denso 234-4125, and either one will cost you a lot more than $46. There's a reason for that.
What did you replace the primary sensor with?
Old 01-10-2011, 06:08 AM
maat4449's Avatar
the up stream o2 sensor was deneso and i had a code for that but the code went away when i install the part. i orginaly had 3 codes, po141, and p1298ELD,
Old 01-10-2011, 10:58 AM
maat4449's Avatar
YOU WHERE RIGHT IT WAS THE SENSOR, THE PART DIDNT FIT... THANKS
Pothole987
Honda Civic (2001 - 2005)
08-23-2011 08:22 PM
dbailey
21
11-09-2007 07:08 AM
sick93sol
08-05-2007 03:50 AM
boltnut
01-07-2006 08:43 PM
Quick Reply: 02 sensor code p0141 seconary sensory light wont go out
