zex nitrous
Re: zex nitrous (ransack)
Fuel rail isn't necessary, don't retard your timing until you go over a 55shot. You don't need new injectors either...until you decide how much you're going to run. I've been running a 65 on my si for about six months now, I spray almost every day. No retarded timing...just an AEM fpr, CAI.
Banned
Re: zex nitrous (civicman)
You dont really need a fuel rail, or injectors yet. But if you want a higher shot then you would need a new fuel pump first, then rail and injectors down the line. the zex kit for your car would comes with 55,65, and 75 shot kits. I personally wouldnt run over a 65 shot on a stock sohc motor. I have also heard about sohc clutches slipping due to the nitrous.
So you would be fine if you wanted to get the zex. They say to use colder plugs and retard your timing if you go above a 55 shot.
I am running a 65 shot on my b18c, but i need a new fuel pump because the stock civic one isnt cutting it. I am purposed running a larger fuel jet until i get a new fuel pump, cause i dont wanna run lean. hope this helps. later
Here are some pics of my freinds focus that was running a nx kit. ran fine for 6 months, bumped it up to the 75 shot last night at the track...
I know that there are people that run N2O with no problems but is it worth it when somthing goes wrong?
Re: zex nitrous (ninetfivehatch)
Details please!
Details please!
Re: zex nitrous (cbrf3)
New User
Re: zex nitrous (dmotoguy)
looks like the NX wet kit gone wrong.
Details please!
Details please!
i did it and i had it on my 2000 civic ex.
no problems, just keep a close eye on your spark plugs, check for detonation after every run until you get your fuel and timing right.
After that you can just change your plugs after every 2 bottles.
I ran the 55 shot and had a lotta fun w/ it.
I couldn't drive when i had it, and plus i always sprayed off the line so i never got any traction. Best time was 15.5 should have gotten 15.0 or 14.9 honestly. I had no skills at the track and it was my first time w/ nitrous and at the track.
Full interior on 17 konig rims.
Re: zex nitrous (97hb)
that's an oddity, everybody knows N2O is not flammable. It didn't CAUSE the fire, but may have fed it quite well though. I run a B18C5 with a 75 shot in a 00 coupe, and have never, ever, had anything go as horribly wrong as that. I did blow the jet out of the line and spray my engine compartment once, but it was all Frosty the Snowman under my hood, no big booming flames...
Re: zex nitrous (F4sTl4N3)
Yeah, but the wet kit adds the fuel and nitrous to one nozzle in the intake pipe(unless direct port). If the fuel puddles in the intake pipe and gets hot enough, bam intake backfire . Thats the worst I have seen yet.
91integraLSVTEC
09-29-2007 12:42 PM
