Zex DRY Kit question
Old Aug 30, 2007 | 01:24 PM
N1 Andy's Avatar
R.I.P. Andy
Default Zex DRY Kit question
I am trying to run about a 75 shot, I went and bought a .036 jet for the no2 part, but what diameter jet do I run on the vacuum (fuel) side for the zex box? if im using the .036 nitrous jet? sorry I searched for a long time and found nothing usefull. Thanks in advance!
Old Aug 30, 2007 | 01:30 PM
foumer's Avatar
W95 gives me a hard-on
Default Re: Zex DRY Kit question (N1 Andy)
I dont get what you are asking. If you are using a dry kit, you dont need a fuel jet. The fuel will be provided by you larger injectors.
Old Aug 30, 2007 | 04:19 PM
rwcdrums's Avatar
Default Re: Zex DRY Kit question (foumer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foumer &raquo;</TD></TR><TR><TD CLASS="quote">I dont get what you are asking. If you are using a dry kit, you dont need a fuel jet. The fuel will be provided by you larger injectors.</TD></TR></TABLE>
this is not correct. N1 Andy is correct. On a dry kit there are still 2 jets. The nitrous jet and the vacuum (fuel jet). Zex states 38 on the nitrous jet and 32 on the fuel jet for a 75 shot. They also recommend retarding the ignition by 4 degrees.
This information comes straight from Zex.
Here's the pdf file. Info is on page 9.
http://zex.com/Base/Instructions/ZEX109.pdf
Old Aug 30, 2007 | 11:03 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: Zex DRY Kit question (rwcdrums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rwcdrums &raquo;</TD></TR><TR><TD CLASS="quote">
thank you very much! I got it together and it pulls really strong! I also used N.O.S. brand jets, so for future reference they do work together
Old Aug 31, 2007 | 04:51 AM
rwcdrums's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N1 Andy &raquo;</TD></TR><TR><TD CLASS="quote">
no problem.
91whiteZCrex
Apr 30, 2006 04:37 PM
djtony5
Feb 24, 2006 01:03 PM
rextec
Oct 28, 2004 08:38 PM
DOHC VTEC EG
Feb 5, 2004 05:33 PM
InjectedSS
Mar 6, 2003 09:14 AM
