Z6 swap. NEED HELP
Z6 swap. NEED HELP
hey so i got a 97 EK 5 speed. i had the D16Y7. and then decieded to swap heads for the Z6. I got a Skunk2 intake manni, OBD2 to OBD1 conv. harness. dizzy... everything pretty much. Put it all in at the same time. when me and my buddy did the swap were pretty sure we did it all right. But when we start it, it bogs down when i give it gas? not sure why. But when i put the stock OBD2 ECU back in it works fine? but it only bogs when i run the P28. Iv heard it could be the injectors but not sure so i was hopein someone on here could help me out.
Would be appreciated... Thanks
Re: Z6 swap. NEED HELP
I'll have to check mine but I thought I read somewhere that a p28 was a auto will check when I get off work in the morning
I think the P28 ecu can be either Auto or Manual. Both from the Z6, that's what I always thought.
I think just chipping your Auto/Manual ecu and it will run fine.
and my p28 is chipped with S100 but nothin on it cause it should run fine as long as i got a base map for VTEC. whitch i do so idk what the hell is wrong with my car lol.
Also does S100 have boost options?
