yet another vtec wiring question, exclusively for 92 civics/delsols :D
Re: yet another vtec wiring question, exclusively for 92 civics/delsols :D (HmgLauj69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 »</TD></TR><TR><TD CLASS="quote">quick fact:
92 models came with pre-wired vtec at the ecu plugs but not the wire harness itself.
here's where the questions comes in. 95 gsr motor/harness into 92 civic nonvtec chasis, do i need to wire in the knock sensor and secondaries from ecu plugs to shock tower or is it pre-wired?
according to a source if i use a si/ex harness i NEED to wire the knock and secondaries but i dont know if it's from the the sensor-to-shock tower or ecu plug-to-shock tower that needs to be wire, thus the question above.</TD></TR></TABLE>
You will need to wire up the knock sensor and the IABs. If you are using the GSR harness, you will need to wire those wires from the shock tower to the ECU. IF you use an Si harness, you need to wire it up from the plugs to the shock tower to the ECU.
