y8 in ek hatch
y8 in ek hatch
sup guys just got a 97 ek with a 00 y8 swap..
its running the stock ecu still. Ive got a prob.. the speedo and tach dont work. the previous owner told me i just need a vtec ecu p2p i assume.. and that will fix the problem . But today i noticed when the car is put in reverse the speedo jumps around 30mph -70mph. just idling it jumps while the car is in reverse. You think i have a bad vss and i just need the p2p ecu to control the tach or i got bigger problems. thanks in advance
i didnt do the swap so i personally do not know. im just goin off what the guy told me.. the car runs perfect just the tach dont work and neither does the speedo.. ill check out the sensor
HT White Ops
Why why why why why ...... do people come on here, bitching that their car doesn't run right when they don't even bother to run the right ecu?
Step 1: Replace ECU.
TEST
Step 2: If problem persists, repace VSS.
TEST
Step 3: If problem persits, ASK AGAIN
TEST
TEST
i checked the vss and it looks fine. as for the ecu . for some reason theres a p2t in the 99-00 si . so im not sure if this has a problem to do with my speedo and tach.. i think imma still buy a p2p and sell the p2t cause my redline is too high for a sohc
Re: (civicrida3)
try and see if your are getting power to the vss or check the ecu for any codes, cause I can put any ecu in my car and the speedo will still work, so I doubt its the ecu but check the wiring on the vss make sure u got power there
well i know the vss is getting power cause when i put the car in reverse the speedo starts moving.. Im thinking the cluster might just be bad.. im goin 99-00 si this week so ill know then. How about the tach? do i have to rewire something to get this too work?
HT White Ops
Re: (civicrida3)
REPLACE YOUR ECU.
And just because your VSS works in reverse does not mean it's not fried. They don't usually just QUIT, they just kind of get all wonky.
the p2p ecu is a bitch to install.
they y7 ( your ecu) looks for 190cc injectors, this may be a problem (rich) as if you have a true Y8 in there intake and all you will have 240cc's in there. also you will need a knock sensor wired up, also a pain as you need a shileded grounded wire. Next you must have a 2 wire iacv with the iacv fix. Its all a pain but the car will pull way better. you must have the nasty Y7 intake on there now.
(throttle body straight upword) if so you need;
d16y8 intake
d16y8 or integra injectors
p2p ecu
knock sensor and wiring
d16y8 iac, throttle body, rail and regulator.
everything else i think can be modified changed or extended to work. It just took me 2 weeks to make mine work right. I think it was worth it, wasa smoother.
Steve
d16y8 intake
p2p ecu
Steve
if got a y8 swap full motor ... i bought the car with the y8 swap in the car i looked at the ecu today and its got a p2t which is a 99-00 si i thought it still had the stock y7 ecu.. Im not really concerned with the tach . but im buying a 99-00 si cluster this week if the speedo doesnt work ill replace the vss and from there ill look into the wiring. But i cant figure out why its not working but when the car is in reverse the speedo starts hoping around
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Couldn't he just run a virgin p28 with a conversion harness? Smooth a lot of that nonsense out?</TD></TR></TABLE>
yah i could that was a option.. but the car runs fine. its a little sluggy down bottom im thinking from the wrong ecu the b16 (p2t) .. but i just want to get my speedo working
HT White Ops
Re: (civicrida3)
Then go snag a vss from a junkyard or ebay, and then replace that ECU asap. I was running a chipped ecu, and having a problem like you're having ... and I found out why. They forgot to jump J1, so I was running a B18B off a P06 map (d15b7)
yah. i c. well imma put a p2p 96-00 ex and sell the p2t si ecu... im getting a new cluster and vss .. so i know one of these will solve the problem hopefully
HamsterStyle
11-10-2004 07:18 AM
