y7/z6 mini me swap troubles..
Old 03-04-2006, 08:28 PM
chippy's Avatar
Default y7/z6 mini me swap troubles..
I just got done swapping my head.. but i'm getting a windy sound on it.. is it something to do with my water pump?
Old 03-04-2006, 08:51 PM
chippy's Avatar
Default Re: y7/z6 mini me swap troubles.. (chippy)
well it's petty much completed.. we swapped in a z6 head on the y7 block.. everythings seems to be working.. the only thing is vtec isn't hooked up.. and i ghetto rigged my y7 distributor on there untill i could find a z6 distributor. I drove it around without vtec it did have a little more kick on the top end.. but i lost power on the lowend due to the lower compression. Everything seems to be fine it idles at 800-1000rpms which is roughly okay.. but back to the point it still makes that really windy sound when i drive.. like the earlier post i think it's the water pump bearing.. but i am not too sure.
Old 03-04-2006, 09:19 PM
freakasis's Avatar
if it sounds like it comming from the water pump than its prolly the water pump.
Old 03-05-2006, 11:58 PM
n2oef's Avatar
Default Re: (freakasis)
which timing belt u use?
Old 03-06-2006, 05:06 AM
chippy's Avatar
Default Re: (n2oef)
i reused my y7 timing belt.
Old 03-06-2006, 08:32 AM
freakasis's Avatar
did you change the water pump? how many miles does it have on it?
Old 03-06-2006, 11:30 AM
chippy's Avatar
my engine only had like 58k when i swapped in the z6 head.
crxsi1
12
08-01-2013 12:32 PM
CivicxTree754
11-15-2011 01:23 AM
Red_ED8
04-14-2008 06:03 AM
hb_guy
01-26-2006 06:04 PM
YumVTEC
09-27-2004 11:54 AM
Quick Reply: y7/z6 mini me swap troubles..
