y7 fuel rail/injectors on y8 IM?
about to buy a y8 IM. missing fuel rail/injectors. will the parts from a y7 work w/o any trouble? it is designed weird, so im not even sure if the fuel rail is designed the same. thanks
just either pop the injectors out of the old rail and into the y8 or just put the y7 rail right into the y8 IM.... however, the y8 injectors have a larger flow rate than the y7, so you will be fine without swapping to the y8 injectors so long as you arent swapping the head
Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian »</TD></TR><TR><TD CLASS="quote">however, the y8 injectors have a larger flow rate than the y7, so you will be fine without swapping to the y8 injectors so long as you arent swapping the head</TD></TR></TABLE>
Nope, they are all 240cc. You'll be fine.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Nope, they are all 240cc. You'll be fine.</TD></TR></TABLE>
bah.... they are not the same.
Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian »</TD></TR><TR><TD CLASS="quote">just either pop the injectors out of the old rail and into the y8 or just put the y7 rail right into the y8 IM.... </TD></TR></TABLE>
so if i use the y7 injectors and fuel rail, put them on the y8 IM. i should be fine on the stock y7 head. thanks. they will be soon upgraded b/c i am going boost. but for now low boost and fmu will work.
Go Tigers!
Re: (soccaian)
i need a confirmation on whether or not this works.
WILL A d16y7 fuel rail fit onto a d16y8 intake manifold.
I have my own d15b7 injectors 235.
i know i'm digging this out of the archives, but i need this question answered, i searched and found this thread, no need to have another thread
Ok for a confirmation what I did was swap a y5 manifold (almost like the y8 but a little diff) on my y7. I used the y7 fuel rail b/c the y5 input for the fuel was in the wrong spot and my fuel hose wouldn't reach. I have pics of it too.
http://os5.servehttp.com/gallery/intake/P2190003 Look at my other stuff on my gallery too
NHB
04-03-2007 04:29 AM
lkailburn
75
05-09-2005 01:06 PM
WickidSi
10-06-2003 06:28 PM
