y1 tranny worth rebuilding?
I'm trying to go boost (only ~250hp) in a ek w a b16. Im determining if i should rebuild my tranny or get a different one. Money is somewhat tight, so my plan was to buy a synchro kit for 1-5 and a new diff bearing because tranny was beginning to grind 3rd and 2nd. Any recommendations?
ALSO the bellhousing has a little crack, can i replace w any cable b series housing?
thanks
thanks
Re: y1 tranny worth rebuilding?
Buy one that's already rebuilt perhaps.
If you're just going for horsepower and not times I wouldn't be worrying about the transmission. Used Honda transmissions are cheap.
Yeah thats true.. so best bet is to sell this one and just save up for a gsr tranny or something along those lines? Im just so sketched out buying trannys because theres alotta shady people where i live so who knows if its b/s or not w/o actually driving it
Yeah and that's the problem sadly! Best case scenario would be able to test it out before driving and make a mark on it to make sure it's the same transmission. BUUUUT, that's rare to happen.
You can determine ^this without needing to drive it. Request you and seller open up the trans and give a good visual inspection.
jdmcivic1
10-22-2007 02:57 PM
Grip
23
02-16-2004 12:09 PM
