Window problem ???help!!****
car: 1996 civic sedan
Problem: pass side power window not working then the rear passenger side power window stopped working and then the rear driver side power window stopped working now the only window that works is drivers??
For the past year i have been trying to figure this problem out, i even had a garage check it out, with no fix.When the pass side window stopped working i bought a new motor and put it in and the same problem so i gave up. Then the rest of the windows stopped working.Unfortunately my pass rear window was smashed while in a parking lot, so i had to get a new window and i told the guy at the window place that it did not work and he said he would try and jump the window. I picked up the car and there was a new window in it he said he jumped it and it worked??? so i assumed there was a wiring problem , I checked the connections with a test light due to lack of any other form of testing and the light light up and the fuses are good.???i don't know what the problem is??If you read through my whole story please try and help me out ? anyone have this problem?
Re: Window problem ???help!!****
i posted this in another place....but what worked for me, EVEN THOUGH THE FUSES LOOK FINE/NOT BLOWN, replace them. i found build up on the fuses that makes the connection not work. try just replacing them.
oldskoolDA6
05-02-2008 05:45 AM
