Power Window Problems
Old Jun 24, 2004 | 10:58 AM
ericlee303's Avatar
Default Power Window Problems
Thanks for the help guys and girls.
I'm having a wierd problem with my driver power window. Half way down, it seems to be getting pinched or stuck on something and the window just stops rolling down. After a few tries, it will continue rolling down.
Is there a way to adjust this?
Eric
Old Jun 24, 2004 | 11:10 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Have you lubed up yet? The window friction areas.
Old Jun 24, 2004 | 11:22 AM
DC2R714's Avatar
Default Re: (Rguy)
samething happens on my passenger side. I took it to Acura and they "claimed" to fix it. Still happens. I think the motors are weak as ****. I been trying to have them replaced under warranty but they keep telling me there is nothing wrong. I have greased those spots and fiddled with the position of the window.
Old Jun 24, 2004 | 11:40 AM
RiCE On IcE 2's Avatar
Default Re: (DC2R714)
u can try sprayign some silicon on the sides I did that... but if u get silicon on the window u gotta use alcohol to get it off.
Old Jun 24, 2004 | 11:45 AM
ZygSpeed's Avatar
Default Re: (RiCE On IcE 2)
Sometimes it helps to keep the revs up around ~1500 and generate a little extra voltage to help things out.
Old Jun 24, 2004 | 12:00 PM
ericlee303's Avatar
Default Re: (zygspeed)
Thanks for the suggestions guys!
Old Jun 24, 2004 | 12:32 PM
DragII's Avatar
25 Year Member
Default Re: (ericlee303)
my passenger window does it, haven't bothered to fix it yet though.
Old Jun 24, 2004 | 12:37 PM
DC2fanboy's Avatar
Default Re: Power Window Problems (ericlee303)
This is a somewhat common problem, especially in the summer.
It is more noticible on the passenger side usually, you can try to lube the track (on the outside of the door where the pin goes) while the window is down and roll it up and down a couple times to see if that helps...
Otherwise... wait for fall/winter...
Old Jun 24, 2004 | 05:56 PM
Dr Pooface's Avatar
Default Re: Power Window Problems (DC2fanboy)
The power windows in our cars are soooo wack.
Old Jun 24, 2004 | 06:01 PM
Sukebei Oni's Avatar
Default Re: Power Window Problems (Dr Pooface)
do you live in a snowy area?
hondaEg_808
Nov 30, 2010 12:35 AM
damdash
Jun 24, 2009 05:08 PM
tekniq
33
Aug 3, 2008 09:26 PM
duffman1278
Mar 6, 2008 02:49 PM
