will i max out my stock 240cc injectors? ls/vtec setup?
Old 11-21-2007, 09:48 AM
Lordofdark176's Avatar
Default will i max out my stock 240cc injectors? ls/vtec setup?
ok i have a b18b1 block with a b16 head, ITR cams and valvetrain currently on 450cc dsm injectors (previous owner had it boosted, im n/a now). My question is im sick of it dumping so much damn fuel and wasting gas (i know i need it tuned, just dont have the funds right now). i have some 240cc injectors i can put in, but should i do it? will i max them out? or will i be fine?
Old 11-21-2007, 09:50 AM
fmrprojects's Avatar
Default Re: will i max out my stock 240cc injectors? ls/vtec setup? (Lordofdark176)
if you on stock compression the stock injectors will be sufficient for the setup. 450 will be over kill
Old 11-21-2007, 10:10 AM
its going to be higher compression than an integra ls because of the b16 head, i did a compression test and got between 235 and 250 across the cyclinders (depending on how many times i cranked over). i am estimating im at like 10.5:1 compression, sound right?
Old 11-21-2007, 12:12 PM
raphael's Avatar
Default Re: (Lordofdark176)
youll be ok with the 240cc injectors. BTW what pistons do you have? if its stock ls pistons than thats not bad at all
Old 11-21-2007, 12:31 PM
serio_ENDLESS's Avatar
it will be ok on the 240's ive done many swaps and stuck stock b20
Old 11-21-2007, 12:37 PM
raphael's Avatar
Default Re: (serio_ENDLESS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serio_ENDLESS &raquo;</TD></TR><TR><TD CLASS="quote">it will be ok on the 240's ive done many swaps and stuck stock b20</TD></TR></TABLE>wow stock block b20...
Old 11-21-2007, 08:42 PM
Default Re: (raphael)
yeah whole bottom end is stock (to my knoledge, a couple people thnk they remember the previous owner putting rod bolts and main bearings in, but until i find out forsure im not taking it over 7500.
nengx07
06-01-2010 08:49 AM
LILSOWEK
10-18-2006 04:08 PM
Shelton
06-10-2004 07:56 AM
GapxGuy
04-25-2004 01:21 PM
skribblah
16
09-06-2003 09:50 AM
Quick Reply: will i max out my stock 240cc injectors? ls/vtec setup?
