injectors
Old Oct 17, 2006 | 11:26 AM
LILSOWEK's Avatar
Default injectors
ok well let me inform you guys, im 18 years old and im rookie with car upgrades, im trying to learn more on how to upgrade my car by myself. So currently im building a gsr bored to 81.5 mm with 11:1 compression pistons, i was just wondering if the stock injectors are fine, and basically how do i know when i need bigger injectors???
Old Oct 17, 2006 | 02:20 PM
94BlueGSR's Avatar
Default Re: injectors (LILSOWEK)
If you're going N/A (Naturally Aspirated), then stock injectors will be fine for now.
If you're going Turbo, you will need some bigger injectors. Anything Forced Induction, you need bigger injectors.
Old Oct 17, 2006 | 02:52 PM
dohcMONSTER's Avatar
Default Re: injectors (94BlueGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">If you're going N/A (Naturally Aspirated), then stock injectors will be fine for now.
not entirely true, stock injectors can handle about 200whp max. But anything after 80% duty cycle will start to be sketchy. it really depends on your power goals
Old Oct 17, 2006 | 03:04 PM
94BlueGSR's Avatar
Default Re: injectors (dohcMONSTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER &raquo;</TD></TR><TR><TD CLASS="quote">
not entirely true, stock injectors can handle about 200whp max. But anything after 80% duty cycle will start to be sketchy. it really depends on your power goals</TD></TR></TABLE>
thats why i said "for now". lol. he's only bored it with pistons.
My buddy has a Drag Turbo kit on his GSR. He's running 310cc injectors at around 295whp @ 10psi.
Old Oct 18, 2006 | 03:38 PM
LILSOWEK's Avatar
ok, thanks for the help guyz, what would would guyz recomend to be my next upgrade??? im n/a for now. this engine swap with 11:1 compression is the first upgrade im doing. also, streetlight flywheel and act xt clutch. I also got the tokiko suspension rak502.
Old Oct 18, 2006 | 04:08 PM
95dc2teg's Avatar
Default Re: (LILSOWEK)
wouldnt he by SLIGHTLY close to maxxing those out?
baggedd50
13
Mar 4, 2012 12:58 PM
bootlegtrader
10
Sep 19, 2005 05:40 AM
mprelude
Nov 27, 2004 03:25 PM
toooslow
May 9, 2003 09:29 AM
