Will anything bad happen if you rotate the crankshaft pulley clockwise too far?
Old 07-16-2002, 01:02 PM
Milano97's Avatar
Default Will anything bad happen if you rotate the crankshaft pulley clockwise too far?
Hey,
Say you are lining up TDC for the #1 piston, and you kinda off past the mark...can you turn the crankshaft pulley back the other way (clockwise) to get it right? I know the crank turns counterclockwise, but isn't it a bitch to go over the mark and have to keep on turning the pulley to line up again? I've decided not to change the timing belt but instead to adjust my valves, I'm gonna shell out the whatever amount it is to change the belt. Thanks again.
Old 07-16-2002, 01:14 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Will anything bad happen if you rotate the crankshaft pulley clockwise too far? (Milano97)
shouldn't be a problem unless you heard a cracking sound or it became harder to rotate as you turned it.
Old 07-16-2002, 01:58 PM
Milano97's Avatar
Default Re: Will anything bad happen if you rotate the crankshaft pulley clockwise too far? (Archidictus)
Alright cool, thanks man...I guess I am just being over paranoid about changing a timing belt which is why I decided just to do my valves then bring the car to a dealer for the belt change. I just hear all these horror stories that it's so hard to do and if you mess up your engine will blow up and whatever. Maybe it is true, I have yet to see it. I got a Helm's manual, but still have some questions. It's just that some people scared me into thinking it's the hardest thing in the world. I guess some stuff gets exaggerated? I dunno, it's cool though. Thanks again for the reply.
crvglenn
Honda CR-V & Element
08-20-2017 01:44 AM
hmtcrxsir
18
12-06-2014 03:17 AM
hmtcrxsir
12-22-2009 10:21 AM
kidcool1977
11-30-2007 06:10 AM
DocSean
01-16-2006 09:20 PM
Quick Reply: Will anything bad happen if you rotate the crankshaft pulley clockwise too far?
