will 96 GSR master cylinder/brake booster work on a 93 cx???
im doing a complete front and rear brake swap from a 96 GSR onto my 93 cx. will the brake booster and master cylinder directly bolt on and work without any modifications. i did a search on this and i see people with problems with ABS and such. TIA
New User
Re: will 96 GSR master cylinder/brake booster work on a 93 cx??? (Quik Chris)
What motor is in the hatch? I've only heard of the intake mani. getting in the way... But basicly it is plug and play.
Re: will 96 GSR master cylinder/brake booster work on a 93 cx??? (976)
except for the fact that u have to reflare the brake lines to fit the gsr master cylinder. the locations where the brake lines go are in different locations on the gsr M/C. u need to reflare the metal brake lines and bend them carefully to get them to fit the gsr M/C. other than that teh brake booster is a direct bolt on and the gsr M/C is a direct bolt onto the booster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">What motor is in the hatch? I've only heard of the intake mani. getting in the way... But basicly it is plug and play. </TD></TR></TABLE>
Yeah, I had the damnedest time getting the brake booster into that little slot... I took the variable runner (VVIS) diaphram out to do it.
Moderator
Re: will 96 GSR master cylinder/brake booster work on a 93 cx??? (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">except for the fact that u have to reflare the brake lines to fit the gsr master cylinder. the locations where the brake lines go are in different locations on the gsr M/C. u need to reflare the metal brake lines and bend them carefully to get them to fit the gsr M/C. other than that teh brake booster is a direct bolt on and the gsr M/C is a direct bolt onto the booster.</TD></TR></TABLE>
have fun flaring the line....
Re: will 96 GSR master cylinder/brake booster work on a 93 cx??? (lilredridinghood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredridinghood »</TD></TR><TR><TD CLASS="quote">im doing a complete front and rear brake swap from a 96 GSR onto my 93 cx. will the brake booster and master cylinder directly bolt on and work without any modifications.</TD></TR></TABLE>
No, you will have to re-flare the line closest to the firewall.
If you want something that is bolt-on, get a 15/16 MC from any non-abs equipped integra or a 1991 Civic Sedan EX 15/16 MC will bolt up to your stock booster.
Re: will 96 GSR master cylinder/brake booster work on a 93 cx??? (Kalokohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan »</TD></TR><TR><TD CLASS="quote">
If you want something that is bolt-on, get a 15/16 MC from any non-abs equipped integra or a 1991 Civic Sedan EX 15/16 MC will bolt up to your stock booster.</TD></TR></TABLE>
yes you will need to reflare a line
Former Moderator
Bingo.
1994-1995 Integra RS m/c and booster bolt up and are 100% plug and play - lines and all. they were non-ABS.
You'll need a double flaring tool and some patience if you want to rig the GS-R and LS versions to work right.
Save yourself the trouble and potential of ruining a brake line - get either the Integra RS booster/M/c combo or get the 1991 EX 4-door m/c and run your stock booster with it.
Bingo.
crush
10-20-2005 07:20 PM
Leb_CRX
01-31-2005 08:40 PM
curiousgpnoy
04-10-2004 08:28 AM
JSJ EG6
13
09-19-2002 11:05 AM
