92-95 cx hatch brake upgrade???????????
i have 95 gsr disc converion fron and back. ss brake lines, integra porpotioing vavle off an ls and a booster off an si hatch buth te master cylinder is still the 13/16 my braking seems week but better than stock pedal is not as firm as i need it. I need to know what booster and master cylinder fits on the cx hatch and will itmake a huge difference if not just what mc will fit straight in.
Re: 92-95 cx hatch brake upgrade??????????? (crush)
you can use the master cylinder off a 91 civic ex it a 15/16 and you wouldn't have to replace your brake booster.
I'm doing the same conversion on a 92 Civic DX. Can you use the master cylinder / brake booster from a 96 GSR and the proportion valve from a RS?
Side note: the brake lines going to the master cylinder are not in the same locations - Civic DX vs. Integra... Whats the solution?
Thanks
Thanks
1 Post
Re: (socaleg6)
if you get the integra bb/and mc make sure you get the integra ss lines or whatever or you will have to modify your stock ones....also the 40/40 prop valve you can get from any civic or teg with disk on all 4 corners
CivicVX94
16
10-17-2007 07:40 PM
vtecn8ive
04-12-2004 01:53 PM
