will 93 integra rear disc work on a 92 eg hatch?
like title says....I've heard that they will and that they won't but I don't know....so hit me up!!
cute little bastard
Re: will 93 integra rear disc work on a 92 eg hatch? (DOHCta VtAkmn)
It should...
My friend bought a wrecked DA for $300 and swapped the rear disc from it onto his EH2
Re: will 93 integra rear disc work on a 92 eg hatch? (blownEG93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blownEG93 »</TD></TR><TR><TD CLASS="quote">You need the rear disks off a dc integra.</TD></TR></TABLE>
don't listen to this dude
The 93 integra rear disk WILL work on you car...just need the civic 15/16" MC and a 40/40 NON ABS PROP Valve and your set
Re: will 93 integra rear disc work on a 92 eg hatch? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">
The 93 integra rear disk WILL work on you car...just need the civic 15/16" MC and a 40/40 NON ABS PROP Valve and your set </TD></TR></TABLE>
off of a DC2 integra ? . . . . dont think u need to go that far just to get some rear brake discs . .
Re: will 93 integra rear disc work on a 92 eg hatch? (S o C l o s e)
wtf it's stock rear disc I got everythin and I don't know wtf he's talking bout a 40/40 whatever valve.....i just wanna know if thye mount up and work
* B A N N E D *
1 Post
Let the expert simplyfy this for you.
The DA trailing arm bolts up as the stock does. IT WILL WORK.
I cannot guarantee the DA e-brake cables will work. e-brake for rear discs from a EG with rear discs, or a DC will work perfect fitment.
If you are just doing rear discs and not touching the front, you will not need to mess with the Master Cylinder at all. You may want a rear disc proportioning valve. The one that bolts on with NO issues is from a 94 Integra RS cause it didnt have ABS and bolts onto your EG perfectly.
Anymore questions PM me.
1 Post
Re: will 93 integra rear disc work on a 92 eg hatch? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">
the master cylinder upgrade is optional, it improves brake response and pedal feel basically but is not required... im pretty sure you have to have the 40/40 prop valve if your goin from drum to disk
and if you talking bout the master cylinder, the one from the 94 rs is fine, but also the 90-91 civic ex also has the 15/16 m/c that bolts in perfectly...now the prop valve can come from any 90-01 integra (not type r) or 92-95 civic si or ex with disk on 4 corners
1 Post
and ive noticed that quite a few brake threads are popping up
all this stuff has been covered before...learn to search sometimes
heres an faq for integra rears on an eg https://honda-tech.com/zerothread?id=812062
/theres a shitload of info that you can get jus by searching
Re: will 93 integra rear disc work on a 92 eg hatch? (sockvtec)
check it out man. i parted out a DA and i personally put the rear disc brakes on my cousins EG.
So YES IT WILL WORK. EVERYTHING BOLTS UP. there it is thats all you need to know. good luck make sure you get it a little straight your alighnment is gonna be off a bit
1 Post
Re: will 93 integra rear disc work on a 92 eg hatch? (DOHCta VtAkm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCta VtAkm »</TD></TR><TR><TD CLASS="quote">will a 91 rs work?</TD></TR></TABLE>
if your talking bout the prop valve then yes, but i think the master cylinder will require you to also use the booster...not quite sure tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCta VtAkm »</TD></TR><TR><TD CLASS="quote">wtf it's stock rear disc I got everythin and I don't know wtf he's talking bout a 40/40 whatever valve.....i just wanna know if thye mount up and work</TD></TR></TABLE>
hahah i have no idea what hes talking about either haha<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">check it out man. i parted out a DA and i personally put the rear disc brakes on my cousins EG.
So YES IT WILL WORK. EVERYTHING BOLTS UP. there it is thats all you need to know. good luck make sure you get it a little straight your alighnment is gonna be off a bit</TD></TR></TABLE>
agree all you need to know.. done! ive seen it done
The DX Rex
11
05-11-2005 12:38 PM
92B20GSR
10-18-2003 06:42 PM
Yusuke
06-12-2003 03:08 PM
Giuseppe
06-23-2002 01:15 PM
