EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ?
will the rear disk off a 90-93 DA Integra work on my 93 hatch???
i know dc2 rear disk works but the reason i am asking is because the local junkyard usually has ton's of DAs and they had one 95 ls integra there, i pulled the rear disk conversion off for $70 bucks total for both sides but ended up trading it to my boy so i was wondering if i could use the DA rear disk.
thanks.
thanks.
Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (nyhustla2k)
yes it fits, im running DA rear discs on my eg. Im also using the e brake lines and the 90-93 RS prop valve, BB and MC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyhustla2k »</TD></TR><TR><TD CLASS="quote">nice nice thanks </TD></TR></TABLE>
no problem, it was an *** getting the MC and BB in because it barely fit, compared to the stock eg one. and I had to slightly bend the lines to fit the prop valve.
Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (slowturbocx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM *** »</TD></TR><TR><TD CLASS="quote">yeah what he said...</TD></TR></TABLE> ...Post *****
what year teggy rear disc brakes fit on the eg....im thinking about buying a pair for $50, but there are no ebrake lines......time to visit local junkyard....whats the estimated time to install?
Umm How about P.C.D.
Im not sure but it a good recheck cos some DC2 equiped with 4x114.1 pcd while EG is 4x100 pcd.
just want to help you recheck it fit for the plat form and also you nice old wheels.
Correct me if Im worng.
Re: EG Rear Disk Conversion Quick Question, Tried Searching, DA Rear Disk ? ? ? (DSM2fastEG2clean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSM2fastEG2clean »</TD></TR><TR><TD CLASS="quote"> ...Post *****
what year teggy rear disc brakes fit on the eg....im thinking about buying a pair for $50, but there are no ebrake lines......time to visit local junkyard....whats the estimated time to install?</TD></TR></TABLE>
Any rear discs from 90-01 will fit your eg. It took me about 3 hours because I had problems with installing the prop valve. This includes bleeding the brakes too.
Re: (turbosnatch)
so if the DA's fit then EF's would to right. I'm junking my EF cause the shell is beat but I wanted to swap out the disks and engine into a EG.
Re: (turbosnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch »</TD></TR><TR><TD CLASS="quote">will this also include working with a ek dx h.b?</TD></TR></TABLE>
Yes, along with coupes. I put a 92 integra rear disc on a 97 EX coupe.
Brock Brum
10-16-2017 10:23 AM
Civiclized
04-21-2005 04:13 AM
