Will 2/3 dr front bumper fit on a 4 door civic
like the topic states..............bout to get my car painted and thought about puttin the 2/3 dr front bumper on instead of the 4 door bumpers. i need to buy a new fr bumper anyway and wanted to see just what all needed to be done.
i have searched but came up empty, and i have seen it done before just can't remember who or where.
pretty sure you have to have the 2/3 dr front corners also, but what about the fr fenders, and the hood do these things have to be changed also....?
any help is greatly appreciated
Re: Will 2/3 dr front bumper fit on a 4 door civic (Art In Motion)
no
you need to swap the whole front clip just like 99-00 front conversion on a 96-98 and weld he fenders from both models together (cut in half)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">no
you need to swap the whole front clip just like 99-00 front conversion on a 96-98</TD></TR></TABLE>
well i know the head lights are the same for all models if i'm not mistaken.....
anyone else
anyone else
Re: Will 2/3 dr front bumper fit on a 4 door civic (JohnnysEG)
Re: Will 2/3 dr front bumper fit on a 4 door civic (yoshi_1r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi_1r »</TD></TR><TR><TD CLASS="quote">the headlights are the same, but corners are not....</TD></TR></TABLE>
yeeeeaaah.......i knew that, well i guess i'll just keep the ol four door front bumper.
you can do it... it has been done but you have to remove the bumper support bar and heat the corners to pull them back for correct alignment. or you can go the long route like i did and cut the inside of a 2dr bumper out and use the outer shell of the 4dr bumper and with alot of epoxy, fiberglass, bondo, and headace's (lol) youll get er dun...
http://washingtondc.craigslist....html
thats my eg with the 2dr front bumper...
Re: Will 2/3 dr front bumper fit on a 4 door civic (allmotorjdism)
so i guess all you'd need is the 2/3 bumper and corners then just modify the bumper to fit right......
hey man do you have anymore pics of your car.....?
would really like to more pics of that front end if you've got em
thanks
thanks
im pretty sure all u need to do is get the 2/3 door fenders, corners, and bumper, and everything will bolt right up.
you need to swap the whole front clip just like 99-00 front conversion on a 96-98 and weld he fenders from both models together (cut in half)</TD></TR></TABLE>
you do not need to cut 2 fenders and weld together when putting a 99-00 civic front end on the 96-98. everything bolts right up. the only time u cut 2 fenders and weld together is when you put the 99-00 or 96-98 front end on a 92-95.
Re: Will 2/3 dr front bumper fit on a 4 door civic (dxhatch93)
I've done this also and it came out pretty close.I'm fine with it,looks a ton better.Good Luck.
https://honda-tech.com/zerothread?id=937516
peatear01
26
11-18-2010 07:23 PM
Crazy4Honda
14
04-08-2007 10:34 AM
portuflip
17
01-17-2006 11:36 PM
jetpilot
10
09-29-2003 01:53 PM
