who knows how to wire up a jdm swap, with usdm ECU
if you know how to wire up a jdm swap, in a 97 ek with a 99-00 b16a. with a 97 gsr ecu. more to it how do you by past the CFS or how do you wire it up to the ecu
do you have to repin the ecu plug.
help please
help please
Re: who knows how to wire up a jdm swap, with usdm ECU (SI_CRX_AUTOX)
if your using a 96-98 ecu just use ur stock wiring harness on the b16 and u will have to pin in
vtec solenoid = A8
vtec pressure switch = c 15
knock sensor = d6
and if u use a gsr ecu u will need to add in the iab solenoid to ur motor from a gsr
and it pins in at a26
u will also need to switch some of the plugs to ur harness just cut and splice them if they dont plug into the b16 then ur done also if ur o2 sensors arnt 4 wire u will have to make it 4 wire by pinning it in
vtec solenoid = A8
knock sensor = d6
Former Moderator
No need to double post your problem in here.
I told you exactly how to fix your problem and yet you still don't want to listen.
Don't start another thread about this problem - use the other one, thanks.
