white smoke from tail pipe
ya sounds simple...head gasket or its possible rings could be gone but after all this i had all that changed and still smoking!?
But get this its only smoking when i press the breaks at a complete stop and im losing break fluid???
any suggestions?
no oil in my coolant
no coolant in oil pan
179-180 compression in all four
any suggestions?
Seagull Management
Re: white smoke from tail pipe (MrMug3n)
The only thing I can think of is that your sucking brake fluid into the intake. I have heard of this happening before, on a chev half ton, never on a honda though.
Seagull Management
Re: white smoke from tail pipe (94EG8)
just thought i'd add this, take the line that goes from the brake booster to the intake off, at the intake end, cap the hole on the intake and take it for a drive, see if it still smokes, remember you wont have power brakes so drive accordingly. More than likely the rubber bladder in the booster is bad and its allowing brake fluid to get sucked into the intake and burned in the engine.
c1v1c98
08-17-2006 05:16 AM
