car WONT START!! help
Old 05-27-2004, 11:56 AM
aandDavidsaid's Avatar
Default car WONT START!! help
i have a 00 honda civic si wen i was driving it to pick up my lil bro the car just shut down in the middle of the street
the car crank but wont start i pull out the spark plug and crank it and no spark wat do you guy think the problem is ....
wat i did , 1. change the battery 2. change the distributor 3. spark plug 4. took off my home made kill switch from da fuel pump 5 change the starter
could it be the ecu ??
Old 05-27-2004, 12:01 PM
BlownVR's Avatar
Default Re: car WONT START!! help (jdmrac3r)
Maybe try resetting your ecu.. If not that then just check the starter. Im not sure why a newer car like that would do that on you..
Old 05-27-2004, 12:02 PM
Default Re: car WONT START!! help (CivicVXHatch)
i change the starter aready ... im sorry but how do you reset the ecu .. thanx
Old 05-27-2004, 12:08 PM
BUMP!!
Old 05-27-2004, 12:18 PM
rusted_eyes's Avatar
pull the fuse from the fuse box under the hood. I thinks it's 7a(back-up radio) not positive.
Old 05-27-2004, 12:38 PM
Default Re: car WONT START!! help (NA_B16a2)
nop not the fuse i pulled it out and it still didn't start
any other ideas
the car stereo was stolen could that have something to do with it
Old 05-27-2004, 12:49 PM
ttt
Pooping on children
Discosteak's Avatar
does it have an immobilizer?
Old 05-27-2004, 12:54 PM
Default Re: car WONT START!! help (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 &raquo;</TD></TR><TR><TD CLASS="quote">does it have an immobilizer?</TD></TR></TABLE>
What do u mean a kill switch, yea use to
Old 05-27-2004, 02:51 PM
dang page 2 already
Old 05-27-2004, 03:13 PM
HONDATUNER92's Avatar
You said you have no spark. Check the coil. By a new one and try to see if that is what it is.
Take distributor cap off then rotor. Try not to drop the spring for the coil as well.
Old 05-27-2004, 03:22 PM
Colorado <3
918-Hatch's Avatar
its your coil. you said you changed the distributor...but i think its the coil.
Old 05-27-2004, 04:13 PM
MyKey's Avatar
Default Re: (918-Hatch)
most likely your ignitor
Old 05-27-2004, 08:33 PM
civicmon's Avatar
No spark tends to = bad ignitor/coil or both.
Old 05-27-2004, 08:49 PM
hatchy92's Avatar
Default Re: (civicmon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicmon &raquo;</TD></TR><TR><TD CLASS="quote">No spark tends to = bad ignitor/coil or both.</TD></TR></TABLE>
Very true, my bet is the igniter, sometimes the main relay is also bad, but your car is pretty new.
Old 05-27-2004, 10:28 PM
Colorado <3
918-Hatch's Avatar
forgot about the ignitor. it went bad on my car 4 days ago.
Old 05-27-2004, 10:30 PM
JDMlyfestyle's Avatar
Might sound dumb. but i had a ground wiggle loose over time and i replaced everything come to find out it was the little ground on the thermostat housing.
Dark19Acura
04-24-2010 04:47 PM
Stevegunit16
03-17-2007 08:59 PM
fwdftw
52
09-05-2006 11:31 PM
DiSbaDbOi
10
01-11-2005 08:00 PM
chito_zan
34
08-23-2004 10:56 PM
Quick Reply: car WONT START!! help
