where is the plug to check my ecu codes?? *searched*
in addition to my car not starting, we figured it would be helpful to check the codes to see if its throwing any, to kinda point us in the right direction. well, we looked under the carpet on the passenger side kickpannel and theres no plug. as you all know i have a 93 delsol si w/ jdm b16a swap. where is the plug located so i can check the codes or is there another way to check it on my car? thanks again!
Re: (Dyzee)
woman... anyway, reading ownes you... we did read that exact post but we couldnt find that little plug anywhere. in the kick pannel of my car theres a green clip that has two grey plugs in it, one has a red and green wire, one has a blue and green wire. the pic on that post shows a loose plug with black and white wires or somethin. am i supposed to take one of those grey plugs out of the green clip and use it? if not, its not there, we cant find it, could it be anywhere else?
Re: (Dyzee)
sounds like mine. are yours both usually in a clip/plug? if thats the case those two of mine are probly what im suposed to be using and ill just have to unattach the one w/ 2 wire holes, so thanks.
rhoades
10
12-28-2009 12:42 AM
new_climber
09-15-2009 09:22 PM
