when to sleeve
when to sleeve
i'm sure this has been ask tons but i can't find anything. at what point do you need to use the darton sleeves on a b18c block? i want my car to keep up with my truck. so i will be putting a turbo on it. going with stock crank. not sure on pistons and rods yet. i need to do some searching on that. i will be running my b16a head on the gsr block. i don't have the gsr head anymore. i would like 400+ i figure if i'm going to build it i might as well do it right. just not sure when the stock sleeves are a liability.
thanks,
thanks,
Thats a good question. I can't say I know when you should sleeve, but the 400+ hp LHT Performance Type R had Darton Sleeves, so I would say if you're going for 400+ to sleeve the block. Also, what kind of truck do you have that requires 400hp to keep up with it in a civic? I've got a little under 200whp and I've taken every V8 truck I've raced from a roll. I've taken all of them from a dig, except the Silverado SS, it just takes longer to pass them.
You don't have an SRT10 do you?
Re: (OMGWTFBBQ!)
well, i have a turbo charged tahoe. and it stomps the b16a in my car like its a bone stock d series. its awd auto with a 3000rpm stall. best time to date was 13.87. that was with 10* timing and before the meth injection, 4" turbo back exhaust and way better tune. here is a little exhaust vid i did.
http://videos.streetfire.net/v...7.htm
Thats bad ***. I would say you would probably need less than 400+ wheel to take a high 13 second truck though. 350 would put you well into the 13s if you can drive (I'm assuming you can).
Re: (OMGWTFBBQ!)
well, i'm only at 10psi in the truck. the fuel system is good for about 800whp or so. long story short i'm shooting for low 12's high 11's. any how, whats a going price for sleeves? is anyone making high power with out sleeves?
I have no clue what sleeves go for, I dont really see anyone running 12s without them using forced induction.
There is an NA k20 civic here in Tampa running 11s at roughly 380 wheel on the bottle.
Re: (OMGWTFBBQ!)
my friend is getting a bblock sleeved, but crower is making the whole block for him, and he's buying a stroker kit, so hes buyin more **** but hes spendin about 3stacks on it. but he gets a sleeved block for about 1200.
Re: (OMGWTFBBQ!)
k20 would be fun but i don't have that much money. i have to get a dent repair where the wife backed into a truck. and i have to get a new rear bumper. the poor car has been put on the back burner for a looong time so its time to do and redo alot of things to it.
