wheel diameter?
wheel diameter?
would a wheel w/ 195/50/15 be the same diameter as a wheel w/ 205/40/16s?
reason being is that i have 16s right now.. and i might be goin to 15s..
neone have a pic of a wheel w/ 195/50/15 rubber? thanks
Re: wheel diameter? (EG_Si)
if they are the same tire, and the same width wheel, i think they will be about as close to even as possible. not gonna be a visible difference, and speedo won't see it either.
http://www.jadesupra.net/gears/index.html
use this site to find diamter size.. from my past experience with the site it's pretty much on the money .. and I entered in your size's and actuall the 15inch tire will be taller.. but not by much
HT White Ops
Re: wheel diameter? (IM ALL BOB)
use this site to find diamter size...
http://www.miata.net/garage/tirecalc.html
Re: wheel diameter? (BlackDeuceCoupe)
wow I was messing with BDC site.. and if u had a stock tire of 215/65/19.. and u went to a 145/30/13 rim and tire setup... when your speedo reads 60 u actually are going 30.8mph =P... I'm bored
HT White Ops
Stock tire: 185/65/14 (OEM CiViC aka Too Small!)
New tire: 205/40/17 (Aftermarket CiViC aka Too Big!)
Tell me what you think???
if u had a stock tire of 215/65/19...
HT White Ops
...it's the same and does not throw the speedo off one bit...
true most people don't undrstand how 14inch rims are the same as the 17inch rim... but I've been trying to figure out ways to make my gearing closer without changing to a gsr tranny nor getting a higher FD.. and I've noticed that the only other way is to find a tire/wheel combo that will have a smaller diamter but yet give me enough traction on the track
I use this formula to calculate overall tire dia.:
tire width multiplied by aspect ratio(percentage), divided by 12.7, + wheel dia. = o.d.
For ex. :
205 X .4 / 12.7 + 16" = 22.46" o.d.(205/40-16)
195 X .5 / 12.7 + 15" = 22.68" o.d.(195/50-15)
185 X .6 / 12.7 + 14" = 22.74" o.d.(stock tire size for '92-95 civic- 185/60-14)
205 X .4 / 12.7 + 17" = 23.45" o.d.(205/40-17)
205 X .5 / 12.7 + 15" = 23.07" o.d.(205/50-15)
I'd do a 205/50-15. Good tread width and tire availability.
Hope this helps.
[Modified by jg, 4:37 AM 12/5/2002]
[Modified by jg, 4:38 AM 12/5/2002]
For ex. :
Hope this helps.
raverx3m
11-25-2010 01:59 PM
