size of tires
Re: size of tires (95excivic)
wheel as well...I plan on buying a set with-in the next few months and Id like to research what I may buy not brand of wheel just recommendations of size of wheel and tire. thanks!
Re: size of tires (bleek)
it depends on what your expectations are...i would say go for a wheel that is 15" or 16" verses a 17" or bigger, because your tire will be taller and you will have a better ride, and they look better imo..as well as weigh less, depends on what your going for though. Tire wise the stickier the tire the shorter the lifespan. BFG G-force sports are affordable and have gotten good reviews, from what i have read..
Re: size of tires (SmoothCX)
you can run a 205 max on a 6.5" width wheel
215 on a 7" wide. probably wider depending on the tire, but i know this is a fact with azenis
raverx3m
11-25-2010 01:59 PM
