Whats the Maximum boost i can go on my 99 si (Still original pistons)?
hi guys ...
Re: Whats the Maximum boost i can go on my 99 si (Still original pistons)? (CiViC SiR)
Properly tuned a/f ratio I say 10 to 12 psi, there are other variables to consider but if the car is daily driven, and would like to keep it reliable I woudln't go any higher. Remember reliability and longevity are 2 different things.
[Modified by POLLO, 5:24 PM 7/3/2002]
Re: Whats the Maximum boost i can go on my 99 si (POLLO)
I say 10 to 12 psi,and would like to keep it reliable I woudln't go any higher. Remember reliability and longevity are 2 different things.
Re: Whats the Maximum boost i can go on my 99 si (vtecvoodoo)
boosting 12 on stock internals on a b16 is a gamble, if i were you i would do 6 psi daily, and 10 psi at the track, maybe one run with 12 but it will probably do some damage. Good luck!
Re: Whats the Maximum boost i can go on my 99 si (blufke)
high compression = not alot of boost. Prob 6 lbs will b safe. 12 lb will b pushin it.
use low compression pistons, and thicker head gasket, and u can use more boost. 15+
azn_outlaw
12-14-2001 10:39 AM
