Starting Problem Please HELP!
Alrighty here is the situation......whenever I get into my car to start it I put the key into the "on" posistion to hear the fuel pump primer up.....then I turn the key and start it....but then it all of a sudden it boggs down and my car shuts off, the gas pedal isn't responding to me pressing on the gas either......then I try to start it again, now its just turning over without starting at all, then I have to wait about 2 min for the fuel pump to be able to primer up again, then try and start it. Then the same thing happens the first time I tried to start my car......then I play the waiting game again, when i try to start it, I press on the gas pedal until its revving at like 6K ...then I just leave it idling there. It literally takes me about 4 to 5 min. to start my car......getting frustrated here....someone please help...thanks in advance
Re: Starting Problem Please HELP! (93egsi)
check fuel filter and injectors... that's what it sounds like at least... could also be bad spark plugs too widely gapped
Maybe the fuel pump is going, or you have a leak in the fuel line. But that's weird that it would work then not work.
I'm having a similar problem with a 91 civic 4 door lx. The battery is dead, but it will start from a jump. It seems to idle ok, then when I put it in drive and move a few feet, it will stall out.
I haven't figured out why yet, but when I do, I'll let you know what the problem was. Maybe it will be the same thing.
Re: Starting Problem Please HELP! (smithenhiven)
did you check you main fuel relay?.....sound like it might be the problem(from what i just saw on another post)
could be timing... I mean if you are getting it started does it quickly idle and then shut off or can you get it to even idle at all? Maybe could be a bad IACV causing surges.
Re: Starting Problem Please HELP! (mjrage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage »</TD></TR><TR><TD CLASS="quote">could be timing... I mean if you are getting it started does it quickly idle and then shut off or can you get it to even idle at all? Maybe could be a bad IACV causing surges.</TD></TR></TABLE>
well when i do get it started it starts to idle at like 4K then it goes to like 2K, then it just keeps going up and down from 4K to 2K....its really weird
wanna_run
25
02-07-2012 09:11 AM
lilsaigon510
03-29-2005 12:10 AM
Integra_Boi
06-28-2002 04:12 PM
