What tranny ?
Re: What tranny ? (88CRX)
it should bolt right up, but you're going to have to remove the flex plate, replace it with a flywheel, get a clutch, and convert the auto car to a manual
if the flywheel has 6 holes, then yes, the bolt pattern is the same as well as the dimensions....BUT, look at the FLYWHEELS BOLTS on the motor.....if they have AT stamped on them, DO NOT USE.....you have to use MANUAL flywheel bolts......they can be found just about anywhere at any reputable Honda shop, or the dealer
