What tranny ?
Is tranny from 1993 CX (d15ba) 5speed going to fit 1996+hatch with D16Y7 auto tranny?
Re: What tranny ? (88CRX)
it should bolt right up, but you're going to have to remove the flex plate, replace it with a flywheel, get a clutch, and convert the auto car to a manual https://honda-tech.com/forums/images/smilies/emthup.gif
Ok thanks also one question is the flywheel and the clutch from d15ba going to fit d16y7?
if the flywheel has 6 holes, then yes, the bolt pattern is the same as well as the dimensions....BUT, look at the FLYWHEELS BOLTS on the motor.....if they have AT stamped on them, DO NOT USE.....you have to use MANUAL flywheel bolts......they can be found just about anywhere at any reputable Honda shop, or the dealer https://honda-tech.com/forums/images/smilies/emthup.gif
