What sensor is this???
Re: What sensor is this??? (degooser)
naw.....there is coolant behind the senor....dunno wat TW stands for......i dont even know wat it does....i think its a temperture senor but dont quote me
Re: What sensor is this??? (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris »</TD></TR><TR><TD CLASS="quote">Usuially if there's an oil leak in that area, it's the cam seal right above the blue circle. </TD></TR></TABLE>
cam seal, or the vtec solenoid gasket...
Re: What sensor is this??? (eg cookiemonster)
oh ok...cause on my gsr motor its soaked with oil....but its not under the cam seal and i just replaced it with one of those alum ones with 3 o-rings...well the sensor is right under the distributor so are there any other places that oil can leak down on that sensor on a GSR head??
Re: What sensor is this??? (Katman)
Thats the v-tec sensor connector. Yes it would leak oil if the sensor seal is bad. Sometimes people will tap their vtec solenoid for oil feed on their turbo's.
Re: What sensor is this??? (b16matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt »</TD></TR><TR><TD CLASS="quote">Valve cover gasket.</TD></TR></TABLE>
brand new gasket and i also put sealant around it for extra protection...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by degooser »</TD></TR><TR><TD CLASS="quote">
brand new gasket and i also put sealant around it for extra protection...</TD></TR></TABLE>
perhaps the vtec solenoid gasket is old and/or the cam seal that hides behind the vtec solenoid is old...change those at all?
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">Its a coolant or oil sensor, its not VTEC related though.
The vtec solenoid is right above it though.</TD></TR></TABLE>
It's the ECT
Engine Coolant Temperature sensor.
It's the ECT
perhaps the vtec solenoid gasket is old and/or the cam seal that hides behind the vtec solenoid is old...change those at all? </TD></TR></TABLE>
vtec solenoid is new and i put some gasket sealer around that too...cam seal is new replaced with an alumn one with 3 orings....
